Damn!Fingers crossed for you fella
Is there any chance that you knock/vibrate the system as you walk away as it restarts (would explain the odd discrepancies)?Damn!
Three days after unplugging the restart button on the case, and no random restarts in that time despite my PC being on for much of it one just occurred after I stepped away from it for four minutes!
980ti Waterforce - running stock, no tweaks by me. How might I check if it's undervolted, or is it something I'd know if I'd done it?What gpu do you have? And are you running an undervolt? I had something similar with that error message when i was undervolting but not locking the voltage down enough to keep it stable
Well away from the machine, often in another room.Is there any chance that you knock/vibrate the system as you walk away as it restarts (would explain the odd discrepancies)?
Or, are you well away form the machine when it restarts?
Call your local priest!but it's only when I'm not at my desk, and it's never when I'm near it either!
It'll be a pain but could your try physically removing it from the case and running it on a bench? Chasis might be possessed. Or just transferring low rpm fan vibrations.
That's an idea ^^
/The body of Christ compels you...
***It's odd that you had 3 clear days unplugging the reset button. You could unplug the rest of cables from the front panel and short the pins to start - and see how long it runs. It could be the whole header is at fault not just the reset pins.
If I didn't have the webcam covered up, I'd agree!best motion sensor pc build 2020
And you're sure you don't live over consecrated ground?Only. Ever. When. I'm. Not. There.
Hope you get some luck for your efforts...I've just unplugged the power button and LEDs from the header to the mobo (the empty USBs, heaphone and mic must still be connected though) and I'll see how that goes!
It's really extraordinarily strange.
No luck, just restarted again despite disconnecting the on/off button, LEDs etc. And funnily enough, I wasn't there.Hope you get some luck for your efforts...
i may be pee'ing into the wind - but when you leave the computer do you use anything electrical somewhere else - e.g. Kettle, TV, secret iMAC?And funnily enough, I wasn't there.
Before I go and destroy something, what part in particular are you suggesting I remove from the case?
Sorry meant the motherboard. It's a pain, but you've ruled out the usual culprits
Yes, very odd. It just happened again as I walked into the kitchen - I hear the fans revving up and there it goes restarting again. Only. Ever. When. I'm. Not. There.
I think they meant the motherboard (with CPU and memory fitted and obviously your CPU cooler), GPU, PSU and hard drives - basically it's called bench test. Be careful though as you don't want to accidentally touch it whilst it is running. Don't plug in any additional fans though.Before I go and destroy something, what part in particular are you suggesting I remove from the case?
Thank you both - I've had a long think about it, and there is no consistent activity that could be doing something that I am aware of.Potentially daft question: what are you doing when you are away from your comtuter when this happens (eg make a hot drink etc)?
It's just to rule out anything from inside your case interfering with the board (ie it isn't shorting out somewhere).
