We normally order our underlay form online retailers and then fit smoothedge and the underlay ourselves. That means that the carpet fitter then only has to fit the carpet and we don't have the expense of the carpet retailer's underlay prices.s
We have also used a lot of carpets from companies that specialise in end of roll carpet. This saves so much money that we are able to get much better quality carpet for rooms.
However, our most recent carpet fitting was a rear hall way that was only 1.8x2.4 metres which cost is £450.
We went for a Brintons axminster carpet and axminster underlay, all supplied and laid by the carpet retailer, including smoothedge. It was a splurge but it is superb.
To answer the question about where to get quality carpet, most places will have an independent carpet retailer whop will generally be able to supply anything form £20 per square metre to carpets in excess of £80- per square metre.
80/20 wool/polyester is the best for most residential areas and Axminster is the best carpet full stop.
You can get 100% polyester carpets that are pretty good now and are more resistant to staining and can be bleached, etc if you have a dirty dog issue for example.
