- 1 Dec 2015
So, MSI and Asus Joining Aorus Master and ASRock Taichi in offering VRM greater then x570 flagships .
Asus and MSI offering 14 x 90amp phases (believe through twinning / teaming ) across the Vcore .
Aorus master currently plays 14 x 70amps direct through 16 channel PWM
And Taichi is 14 x 50amps using Doublers .
Believe all are on 6 layer PCB . All handling 5000hz ram . I know Aorus 4400hz kit are plug and play on the Master board
you could see in Ryzen master it was effectively power throttling but even when it was it was operating at well over what was outlined on the box as base. The board and processor ended up being changed and she is now on the b450 Aorus M with a 3600. It doesn't bother me as such and power delivery is important but I am starting to see a trend with this and I just feel that to hit the different value price points it shouldn't be all the manufacturers rushing to see who can have the biggest VRM.
