Upgrade advice following Gen 3 Announcement
8 Oct 2020
Hey,
I've been holding off upgrading my PC until the announcement - not going to lie - I'm still more confused then ever after watching it so hoping for a bit of advice
I currently have:
i7 6700k
B150M-K Motherboard
16GB of Kingston DDR4 RAM
RTX 2080 FE
Coolmaster Heatsink for CPU
I'm mainly interested in gaming at 1440p - been looking at buying a new motherboard , a NVME SSD for operating system (currently SSD) a new CPU and possibly a water cooler (kraken looks good as I have a NZXT H500i case)
What would your suggestions be? Better waiting to try get a new Ryzen or look at getting a deal on an i9 or zen 2 chip - I'm completely lost with this ha.
I have that itch and I've been holding off scratching it for a while :D is there anything you would consider upgrading now?
It would (Nov 5th):
  • 5800X ~£350 upwards (5700X will be far better value)
  • Gigabyte B550 Elite or MSI B550 Tomahawk ~£160
  • Crucial Ballistix 3600MHz 32 GB (Micron E die) - £140 (or £70 for 16GB)
Offset the cost by selling your MB, CPU and memory.
It would (Nov 5th):
  • 5800X ~£350 upwards (3700X will be far better value)
Just to confirm mate are you saying it may be better going for the 3700x instead of the 5800x ?
Thanks for your suggestions
No, that was autopilot (sorry - i'm still reading data on paper launch) - i meant you could wait for 5700X.
I'll edit original post otherwise they'll be an influx of posts.
Whats your thoughts on a i5-10600k? they seem like really good price at the minute
My thoughts are they run very hot and deficient in cores/threads - but there's no denying they have their place and decent price with their 'present' performance (But, factor in motherboard and decent cooler)
Personally, in your position, and if i was looking at performance to money ratio (guessing from your suggestion) - i would wait the additional 6 months (if present gaming performance isn't an issue) and buy the 5700X with the additional cores/threads (parity with consoles ports) plus cooler and know that you have really made a significant update and for best bang for buck/longevity.
