to be honest reading your posts you sound like he’ll bend on buying intel regardless what AMD can do. You might as go for it. No point in asking for opinions of your mind is dead set.
looking at the 5900x single core performance and the bench marks, the 5600x for sure will beat 10600k in every respect.
I agree it is too early to tell for def what kinda performance to expect from 5600x and I agree waiting for the actual benchmark will be the best course of action. But before we get there isn't it nice to speculate a bit?Too early to say 5600x is not gonna be equally good. The CCX design of a 6core and 12 core should be identical. The 5900x boosts higher on stock setting and enjoys slightly larger cache. The former will likely to be negated when the CPU is overclocked. And the latter is unlikely to affect that many games.
wait for the reviews to come out and see a) how well the 5600x can clock and b) how it does in games.
On stock clock in games you are probably right. But can you agree that [email protected] is better for gaming than 3600X and actually closer to i9? So in that case I think, that when it comes to 5600X, it potentially could be as good as overclocked 10600K. WIll it be better? It depends on overclocking. True, we do not know that yet, but did any previous RYZEN gave us the reason to think that Zen 3 is gonna overclock well? Not really. And the price? Well - 300$->282pounds with tax. To me it looks like 30 pounds more than 10600K. And I am not looking for cheapest mobo, so please forget about the price difference, because it's marginal.I suspect it will surpass i5 and therefore for the same money you are better off with 5600x and save some money on motherboards.
True of course, but I am craving for new toysAlso it is listing price, when sales season starts you will get discounts or additional items so that will make the ryzen much more attractive especially if they beat intel on games.
Yup!!
After going 4790k > 3600 > 5900x, I think that'll be me done for another number of years.
I loved the tease on the GPU though, that thing looks awesome!!
Yes, makes sense with the processor.I don't think that's probable at all. A 10900K is already an overclocked 10600K and then some, and there's been very little difference for gaming between Ryzen SKUs so far. If anything, the single-CCD chip might even perform a little better. I'd expect it to be slightly faster than an overclocked 10600K. There's also literally zero reason to even consider X570 over B550 (or even B450 unless you want a PCIe 4.0 SSD, which you can't have with Intel), whereas you have to buy Z490 for Intel. That's not to say the 10600K is a bad option (I have one), but it's certainly not as cut and dried as you make it sound.
So in basically just a year, AMD has beat Intel’s entire 2015-2020 IPC advances![]()
Thinking if treating myself to a 5900 as price prob close to 5800.
Currently got i7 2600k at 4.3ghz, so this should be a bit faster.
One thing to ask. (Hope ok to ask here)
I bought a retail copy of Windows 7 (or was it 8 erm anyways) I had a free upgrade to change to Windows 10.
Of I did a full upgrade. How would I go about using Windows 10. Could I somehow claim it and create a disk? Or would I need to buy retail again? (Big cost to poss think about)
Can't say without benchmarks.So, after watching the presentation, I have the dilemma....
Looking to upgrade 4790K. Was lucky and bought 3080 in the lottery. MOSTLY gaming and entertainment @1440p
Give me ONE (or two) good reason why should I get 3600X (or wait for 5600X) over i5 10600K@5GHz??? In gaming it gets close to i9.
If 5900X is going to be faster than i9 (realistically speaking probably 5-7% @1440p), then 5600X is PROBABLY not going to touch overclocked 10600K, which you can get for 250 pounds? 5900X is probably gonna be 550 pounds, Z490 vs X570 prices are similar.
So the way I see it, 10600K@5GHz seems like a best choice in my case?
Well if its unusable then if i were you, and if you are set on buying AMD, then buy an x570 or B550 since you are gonna need one anyways for zen 3 and try getting one of those bundles that comes with a ryzen 5 3600. Standalone those chips go for £180, which you can probably sell second hand on ebay for 100-150 after you get your zen 3 chip. If 6 cores isnt enough, and you NEED 8+ cores then I would just wait till november and try and snag a zen 3. Demand will probably be nothing like the 3080 but im imagining they will still sell out quickly.Both. I use it for gaming and working from home with a few different VMS running and also will be streaming. Currently have a 1080 GPU but trying to pick up a 3080
If overclocking, 10600K may just come out ahead of 5600X. Although averaged gaming gap between them was 13% on AMD slides. Tough to close that.
But you are paying more for a OC capable motherboard and cooling for Intel. Which are optional with AMD.
5600X seems a solid pick up for anyone. Except I made up my mind to go for 8 cores or more. And the 8 core part is a tougher sell
Arg, 4 weeks to wait for actual benchmarks. I will go crazy trying to decide whether chasing that absolute top perf of 5950X is worth it or if the 8 core could be overclocked
Really curious how 3950X to 5950X improvement is significantly bigger than 3900X to 5900X on those slides
