ITX case - SilverStone SUGO 14, any views?
Here is another review on the SUGO 14, is in Chinese but you can turn on English subtitles:
There will be more reviews coming, hopefully we get more positive reviews from here on out. We'll make sure to communicate to those reviewers that received early SUGO 15 samples that they aren't representative of mass production quality!
Do you plan to adjust (lower) prices at all? Finding it hard to justify spending £90 on this vs the NR200P given the performance.
I don't think we will be lowering prices any time soon as the case just came out and our cost if likely higher too.
Please keep in mind that performance is relative to the setup and component configuration you have. Optimum Tech's test shows one such configuration that favors NR200 (with all filters removed), but that does not mean our SUGO 14 is a lower performer overall, you can also build a PC with better cooling inside our case vs. the NR200. The main advantages of SUGO 14 extends to more component compatibility (ATX PSU, 5.25" bay, large air coolers) and features (GPU holder, dual orientation, extra USB front port).
SUGO 14's PSU compartment is in its own vertically orientated space in the chassis so it does not physically affect other components. Whether you have 150mm long ATX PSU or SFX PSU, the space available for other components is the same.
I never did get around to this...but I do still want to do an itx build and this case still looks good considering you can use a cheap atx PSU and it holds a big GPU, did anyone do any builds in it?
Everyone always goes with the NR200 but you need SFX for that....
