AMD Zen 3 (5000 Series), rumored 17% IPC gain.
Status
Not open for further replies.
How can the 5900x be better than the 5800x in games if it has higher latency? Though it says only 3% but still
5900x has higher stock boost clocks, bigger cache. current games will play fine with 6c which is the single CCX on 5900x so the latency effect is negated.
4.8Mhz over 4.7Ghz - 2%
32mb cache vs 64mb cache - must give that 1% more
3600 is 8% behind 10600K in games at 1080p. 5600X is 13% ahead. It is a crazy gain for gaming, much bigger than any 6 to 8 core can give you.
Is this accurate? could you provide a source please mate.
On a 4690k which is struggling so much now, 90%-100% usage in most games. 5.5 years since last upgrade.
May go for a 5600x + B550 Tomahawk/Gaming Plus/Gaming Edge (no idea which)
Extra cache and higher sustained boost due to the spread of cores would probably overcome the performance loss from cross CCD latency.
Will have to wait for reviews I guess to see what's what.
Also only just noticed they are comparing against different Intel processors there, so it must be bit more than 3% difference
8% figure is from TPU https://tpucdn.com/review/intel-core-i5-10600k/images/relative-performance-games-1920-1080.png
13% figure is from AMD slides https://cdn.wccftech.com/wp-content/uploads/2020/10/AMD-Ryzen-5000-Desktop-CPUs_Zen-3-Vermeer_17.png
Of course the set of games is not the same between them
Cheers for the link. At first £290 sounded like a lot for 6 cores but at the end of the day the real world performance is what matters I guess. If the 5600x is 13% faster on average than the 10600k and also faster than the 3700x at the same price point then it would be a no brainer to get the 5600x over those two CPU's. Unless of course you really need the 2 extra cores.
For my situation it's purely gaming. I usually upgrade every 5-6 years so it may be worth just going for the 5600x! Just have to decide what motherboard and memory to get as there is just so much choice!
Side question regarding memory. 3200mhz + CL16 or 3600mhz + CL18 for a 5600x?
I'm just thinking what I can get away with to be honest, while retaining most of gaming performance benefit of the Zen 3 architecture.
The 5800X is expensive for what it is, but it is cheaper than going the 5900X and 5950X route.
And it does have a fully kitted out single chiplet with a higher base clock than the rest of the line up.
We will have to see how it benches when directly compared, but I'm thinking it will be right up there trading blows.
So it could be the way to go you know.
You're one of the only people I know that got a 3300x cpu. They were like hens teeth when you tried to buy one, I ended up getting a stop gap 3600 instead.
Where I live the PC enthusiast population is smaller and retailers only sell within the country, so generally you can get stock of almost anything if you get there within a reasonable time.
I don't think it was very mass-produced or intended to have a particularly long lifespan. Great budget CPU though! :)
It's a weird feeling knowing that, if I ever wanted to, I could just swap my 3900X for a 5900X and not have to change out my X570 motherboard. It certainly feels like I'm getting my money's worth out of the motherboard instead of just ditching it for the next highend one.
Status
