Crysis 3 Installed on RTX 3090 directly
Permabanned
OP
22 Jul 2020
Well he took 15GB VRam as a Ramdrive basically so he is left with 9GB to run the game (so not sure how he saw 20GB usage).
Man of Honour
13 Oct 2006
Interesting but probably little advantage over using a RAM drive of physical RAM unless you can find a way to bypass the normal loading mechanisms which still mean a lot of data being shuttled around by the CPU during the loading process rather than either mapped from the installation footprint and/or directly copied on the GPU to the right location.
Man of Honour
13 Oct 2006
Wonder if you can still get the add-in boards that let you populate them with dimms and had a battery backup to preserve contents - probably these days don't offer much over an nvme drive anyhow.
18 Sep 2020
This isn't that much different from RAMDisk, it's basically just using part of the VRAM as storage and nothing more to it. The game is still bound by coding and ofcourse it's still using the CPU and system RAM.
Man of Honour
13 Oct 2006
Had a gigabyte iram. More annoying than useful. Swollen batteries and limited capacity. Ssd or nvme is much better.
Didn't realise they only had 16 hours battery life as well on the iram - makes it rather less than useful outside of very niche applications. I assumed they'd last weeks or months with just refreshes.
