It's done! Finally tonight, managed to invert the impeller and put it in a test loop to clarify it actually works before putting it back into the system. Did a short video to demonstrate the loop from outlet to bykski flowmeter to inlet back into the pump/res, the flow meter shows the correct readings and no Alarm is shown.
With this sorted, i've rebuilt everything back up and... you know took some pics
Next update will be when Aquacomputer release a block for this card or a 3080 that i might still get. The Kryographics NEXT generation blocks are something that i really want to own
. It can be pretty daunting at first but its really enjoyable and therapeutic once you get into it.
