- 11 Mar 2013
I'm with BT and smart hub 2. Am I ok without using a VPN?
Do I really need one?
Thanks
Thanks
Some people also think because they are using a VPN everything is anonymous. Your data is still stored somewhere, just instead of with your ISP it is to another provider.
Only way you would need it would be for example if you are on a shared Wifi connection like in a hotel.
The UK based servers keep only the bare minimum afaik, so logs which are only really useful for debugging and can't be used to cross-reference the user to the history. The law doesn't say they have to be useful logs
But a VPN is a good idea these days. You stop your own ISP spying on you and they can't shape/throttle your traffic, or block sites. Also useful for buying cheap and tax free games from the Ukraine![]()
you dont need one. its all just a scam.
i have never have one and had zero problems, i do all the normal internet type stuff
only very bad people need them. and this is why i think they need banning
You are wrong. A VPN can also be used to remote into a work place. when it comes to networking you can have services inside of a network. A member of staff (lets say a technician) can remote into the work place to do their duties without compromising security.
yes but why dose "JO Public" need one.
for downloading filmes ? NO
for shopping ? NO
you see where this is going... there is lots of things that are available to people that need them for work but not normal person on the street, this should be the same.
it would be a lot easier to find scammers, pedo's and so on.
for shopping ? NO
for shopping ? NO
In my opinion people have a right to some privacy. I don't believe it is healthy when the government has access to everything we do and think. That's the sort of thing that happens in North Korea, not Northampton. The government can find criminals without monitoring the entire population 24/7.
