Hi all,
My brother currently has no PC at all as his old laptop is nearly dead. So he is looking to buy some of my current parts and buy some new parts to put it in. He will need a new case as I will be keeping my Phanteks enthoo pro m.
He would like a case like mine as it holds a space for a optical drive and only has one slot so it doesnt take much room in the case. My case is a little expensive for him but he would stretch to it if he had to. Are there other cases that would fit his criteria at a lower price? mine is near 100 pounds on OC.
He will be taking my 4770k, MSI GD65 motherboard and team group vulcan ddr3 2400mhz ram and I will probably give him my enermax t40 cpu cooler as I cant find a AM4 mounting kit for it so I would likely need a new cooler.
In my case can I fit AIO radiators at the top? Its just that im considering buying one as I have seen 2018 corsair hydro H60 AIO at good prices and I believe from what I have been reading rival top air coolers in performance. If I go air the Noctua u14s is looking my favourite.
Im also wondering whether to sell my gpu to him as well (MSI rx480 8gb) and look to get something else but not sure.
Any recommendations on which GPU I should upgrade to from this? A lot of the newer cards only come with 6gb ram but are gddr 6 instead of gddr 5 on my current card. If i dont sell my current card I recommended the 1660 super to him as that seems to be the current go to card.
Also what psu and size would you recommend for my brother? preferably I would like him to get a modular psu as they are easier to build with. Also could you recommend any cable extenders as in my current build some of them barely reach their target.
