lian li pc-o11 dynamic rad?
9 Nov 2012
I am going to get a lian li pc-o11 dynamic case and would like to know if a 360mm 30mm thick radiator and 25mm fans in push pull will fit at the bottom of the case. Or could someone please tell me how much height there is at the bottom of the case for radiator and fans.
Horizontally mounted gpu yes no problem for 30mm thick rad however vertically mounted your only option is 20mm ultra slim rads.
Also 30mm rad don’t need push and pull my 360 54mn Rad’s fitted to top and side are in push with 3 intakes. I have the air version
I was thinking of doing a 360 30mm rad on bottom with 3 fans in pull (but thought push pull would be better if it would fit) and a 360 30mm rad at top with 3 fans in push.
The difference is negligible in push pull config, you're better off just doing push or pull.
If your GPU is mounted horizontally on a standard ATX motherboard. (obviously motherboards are all very slightly different height top x16 slot but roughly....)
You roughly have 13.5cm from the PCB (top) of the gpu to the floor of the case. (I have just measured)
So for example if your GPU is a standard 2 slot 3cm. You would have 10.5cm from the bottom of the GPU to the case floor.
In your example 25+30+25= 80mm. It works easily.
You'd have to have a much thicker 3/4 slot card for it to hit.
(The above is on a Asus B550 Gaming F motherboard in a non-XL o11d)
Interesting as i am doing the same. Have an aio at the top for the cpu and was going to mount a cpu rad either at the bottom or preferable the side. Could you not Vertically mount the rad on one side of the mounting and the fans the other side?
I did message lian li to ask them how much room there was top and bottom for rad and fans and they said there is 65mm clearance for rad and fans. So I will probably go with 30mm rads and 25mm fans with bottom rad fans being pull and top rad fans being push.
I have just fitted a 55mm Corsair rad on the top, still clearance, so i would say 60mm top.
bottom i tried the 55 and it does fit
Buy the xl version and u won’t have any worries
This. Much more flexibility. Also, for a thin rad, no point using push/pull, really. Been there, done that, never again.
The XL accommodates 3 360 XT45, not much of an issue running the tubing. Can be simpler if using a 30mm thick for the top, or XFlow.
You can push / pull on the side no problem. You can even get the rad and one set of fans in the back (did it with a h150i).
Done a search and found this vid, maybe usefull to you https://www.youtube.com/watch?v=WypMLCotzW0
That video was really helpful. I would really like to vertically mount the GPU (once I can find a 3080 block I like) so top and side mounting the radiators plus the Phanteks mount would leave space for some fans at the bottom.
Now just to decide whether to stick with the trusty EK res/pump combo or go for a fancy front distro!
