- 22 Mar 2017
- Poland
Oki
Thanks guys
So if it will trip my psu then buy 850W ?any oc'd cpu with a stock clocked 3090 and a 750w psu is more than enough, if you plan to run both cpu and 3090 oc'd then you need minimum 850w and ideally 1000w for the headroom
on the other hand a oc'd cpu and a stock 3080 will run fine on a 750w, maybe a good quality 650w and if you push a oc'd cpu and a oc'd 3080 a 750w will also be ok
The problem is with the 3090's they can pull a huge amount of watts for a split second in games and benchmarks which can trip over current protection on psu's and many 750w units can fall foul, thats why ideally a 850w is recommended for a 3090 setup really even though nvidia don't specify that
So if it will trip my psu then buy 850W ?![]()
Yeah definitely must check first on my psu. Also seen few guys with 650W/750W on youtube with 9700K and Rtx 3090 and they told its fine.IMO, if you had to buy a new PSU, I would be getting a 1000W minimum these days.
I bought an 850W PSU 13 years ago (still going strong, I might add) when that was considered total overkill for my then system.
I just like giving a PSU an easy life, less stress, less problems down the line, just like humans.
But few guys with 750W on youtube dont have restarts with 9700K and 3090750W doesn't seem to be enough. I have one and I am getting system restarts with it so now buying a bigger PSU. You can stop asking questions now![]()
You bought 1000W? You think 750W cant be enough?
[3]I emailed seasonic directly and they said that a 650w power supply isn't good enough as the headroom won't be enough to handle a power spike.
But few guys with 750W on youtube dont have restarts with 9700K and 3090![]()
oki thank you for explanation , really appreciate itit'll all come down to how far you push you overclocks, if your going to run at stock speeds for cpu and gpu then a 750w psu will be fine, a moderate cpu overclock and a gpu at stock will be fine too, BUT running max cpu overclock and max gpu overclock then a 750w will fail and ideally 1000w will be needed.
i ran a 3900x with a big oc of 4.4ghz and a zotac 3080 stock and i was fine on a sf 750w psu, a week later i got lucky and purchasd a zotac 3090 and with a 3900x still at 4.4ghz and a stock 3090, i was fine in games but benchmarks made my pc shut down, when i looked closer i relised my psu was being overloaded for a split second which caused the shutdown issue, fortunatly i had a spare hx 1000w corsair psu which i installed and have had no problems at all i can run my oc cpu and apply +100 core and +500 mem offsets on my 3090 and under gaming or benchmarks everything is super stable, NO SHUTDOWNS
aib cards with 3x8pin pci express cables you really need to look at 1000w+ psu as they will pull a hell of a lot of power under load 480w+ in most cases
Why do you guys keep entertaining this dude.
Its question after question even when he's been given an answer. It's like he wants to remove any chance of thinking for himself.
Worse still he posts quite often in other new threads about things that could be affected by poor power delivery, doh.
Good post that, thanks.ASUS Strix OC has 3x8-pin PCIe connectors.....
Hes exhausting.
I feel bad incase its some kind of autistic trait or something but hes relentless.
okI still think it will be worth trying, maybe you will not run into any problems.
I read rumours that Seasonic Tx had problems with that cards. Its ridiciolous. The most expensive model of Seasonic and issues. Read:
https://www.reddit.com/r/nvidia/comments/j0t2ob/psu_concerns_with_rtx_3090/
"Linus tech tips specifically had a problem with a Seasonic TX-850W tripping its OCP at 50% power draw on the 3090, causing hard resets."
So change that psu for a i dont know COrsaiR?!
https://www.reddit.com/r/Amd/comments/9zd1os/seasonic_updated_statement_after_the/A power supply sold after January 2018 has the updated sensitivity preset of overcurrent protection, so users can use it with confidence.
Funny thing is that it's not a "flaw". OCP generally triggers due to absurdly high transients. Last we heard of these issues with Seasonic was with Vega 64:
Back then Seasonic investigated and essentially said that GPUs are ****** as a single Vega 56 was taking in as much as 600W ALONE.
So if their PSU shuts down, it's not PSU that is a problem. It's GPU which clearly breaks ATX specs. Other PSUs might be fine simply because their filtering is worse (although if Seasonic TX has a problem then all other manufacturers using their designs may too - this applies to Corsair AX and EVGA GS but there are likely more). So if RTX 3090 exhibits same behaviour at 850W, it likely really means it has transient loads exceeding 600W. At which point Nvidia should recall that **** since it's violating specs and add a 3rd 8-pin or decrease the clockspeeds until it no longer asks for absurd amounts of power.
Peaks with intervals between 1 and 10 ms can lead to shutdowns in very fast reacting protective circuits (OPP, OCP), especially in multi-rail power supplies, although the average power consumption is still within the standard. For this card, I would therefore calculate at least 460 to 500 watts as a proportion of the total secondary power consumption of the system with a normal OC with up to 400 watts as the power limit as the graphics card load, in order to have enough reserves for the worst case scenario.
