Are you 7 years old?
Well he's been a member for 13 years , so probably just one of those 30 something men who start arguments online to fill an otherwise empty existence
What part of him was off? Genuinely, I can't see it - can you point it out?Mane was off.
With Newcastle getting an absolute spanking later, that has made my day already
Ive just posted the picture. He isnt offside.Mane was off.
One less than you?
Pre ordered your DVD?
Apart from all the times the have come out and said which decisions they got wrong. but ok, you do you.
Pretty sure his carer would get done for human rights abuses if they force fed him gravy.How many pints of gravy have you had this morning lad?
But so far as I'm aware the "machine" involves a man pausing a video and drawing lines. It's perfectly feasible for him to be wrong. The video running at 60fps won't show the precise moment the ball leaves the passer's boot, and the camera angle isn't usually in line with the play. The tech isn't there to make these decisions down to the nearest mm so they need to stop pretending that it's so precise.I am not a VAR machine.
Just one ones that go against LiVARpoolWhich offside decisions did they say were wrong?
I'm confused why richarlson was sent off as ref already blew? Surely if pickford wasnt then richarlson shouldnt too?
Are you saying that no other fans have thought a VAR offside decision was wrong? For that matter, are you saying that impartial pundits aren't questioning decisions?Just one ones that go against LiVARpool
