Trying to fix the light fitting on an old ceiling mounted fan unit
14 Jul 2005
Birmingham
Hi all,
I have a ceiling mounted fan unit in rented place which has 3 light fittings attached to it, however they are old and damaged.
Some photos below.
The lamp holder units are some kind of older plastic material I think, but they have screw fittings inside them where they screw through and into the metal base you can in the photos. As you can see, these lamp holders are damaged, so I want to replace them. They are E27 ES fittings.
Does anyone know what type of fitting this is and where I can get them from?
Here is a photo of the repaired ceiling fan unit.
What bulbs do you suggest for this? It's a bedroom main light, and doesn't get used a great deal. As you can see it has glass shades which I could have on or off. Could just go for a standard LED golf ball, or something better looking? Not sure it would look right with the glass.
