- 29 Sep 2010
So
I've ported over my pc into a thermaltake core p3, all went well, sorted the runs out nicely and it looks smart with minimal tubing which is what I wanted.
However, when taking a photo with the flash on, it looks as though there is what could be the start of some corrosion/flaking to the nickel on the gpu block
but it also looks like it could just wipe off potentially too, I guess I won't really know until I change coolant, I cannot be bothered to drain it again to refill and bleed it again right now.
https://i.~ibb.co~/2yrdh47/PXL-20201018-213728389.jpg
https://i.~ibb.co~/MBfMBCn/PXL-20201018-213019741.jpg
Completely flushed the gpu multiple times with distilled water, just forgot to take off the plexi to check out the inside
Looking at the location I think it is just a bit of grime as it isn't on the path of the water(apart from the fins) so hopefully just be a wipe down job. Or an excuse to get a new gpu
but it also looks like it could just wipe off potentially too, I guess I won't really know until I change coolant, I cannot be bothered to drain it again to refill and bleed it again right now.https://i.~ibb.co~/2yrdh47/PXL-20201018-213728389.jpg
