upgrading and selling old parts to my brother
My current setup used to run just fine with that psu when I was running my old MSI 7850 gpu but I have no idea how much extra power the 2070 takes in comparison or even in comparison to my rx480 8gb.
Gold are the optimal effeciency/price point overall.
That old psu might striuggle with a 2070 and the rest of the bits in that system. Probably better to get a 650 for it as you dont want ti going pop and taking the whole ssytem with it.
Not for a 4770k 1080p gaming rig. No real need, 550 will be plenty even for a few upgrades as long s he doesnt buy a 3080!! :p
sure.. but if he is buying a new psu its not going to be that much more to buy a 650w one... and he is saving himself some money in the future
True its not as if hes looking for a 1K psu. I just see people speccing massive psu's when the rig they have chosen doesnt need anything near that. With the demise of sli etc very few people will need over 750 psu now depends what the next gen of gpu wattage is like the 3080. Smaller nano process but rated for way more wattage thean the card it replaces (2080ti).
yeah.. i get you.. but i think 650 is a good "future proof" path.. not to much and not to small.
650 should be enough even for 10900k and 3080... but if you want to overclock then i would suggest more..
I have done more psu calculations via other Web sites that all only showing that he will need around 450w psu. The seasonic one is the only one of about 5 that states he would need above 500w and suggests 650w.
Actually Ive just done it again and realised that seasonic are recommending I buy one of their 650w gold psu's. They actually state he will only be using 440w.
Yep. That's what it says. On the description of the gpu it suggests 550w and above. So at least what I'm giving him will fit that.
