Hello, I think my psu is failing and could do with some suggestions to figure out if it is.
It's powering:
Asus 1070 gpu
Asus prime z390-a motherboard
I9 9900k
3TB green drive
120GB ssd
8 GB Corsair vengeance RAM and 8GB(2x4) vengeance RAM
3 LED strips (can't remember brand)
WiFi card (can't remember brand either)
So here's the problem, pretty much out of nowhere my pc has started to have severe restarting problems, sometimes I can run my pc for an hour with no problems whereas other times it goes into a restart loop that's impossible to get out of. The pc even restarts from the BIOS menu if left alone. All the temperatures are fine, I've used software to check all voltages which seemed fine as well as software for temperatures. I've taken everything out and replaced it several times, alternating ram sticks, with and without the gpu and reseated the CPU as well as all wiring for all components. I've noticed that if I take out the 8GB ram stick that the pc "stays on" for longer but always ends in a restart which progressively gets faster and faster until the pc just turns off. I've searched for possible problems and my only conclusion is the PSU but I wanted some opinions and advice before I RMA and ends up not being the PSU. The PSU is only 6ish years old. Thank you anyone for help or suggestions.
It's powering:
Asus 1070 gpu
I9 9900k
3TB green drive
120GB ssd
