Don
List prices in various UK based shops are
1060KF ~£239
1060K ~£249
5600x £289(only overclockers.co.uk has a list price )
Don't forget that for i5-1060K/KF you need a new motherboard, good old b450/x470 will still support 5600x, and 550/570 motherboard have advantage of PCI-e4 storage = faster loading.
Any price difference in favour of i5 gets lost in motherboard upgrade costs, not to mention that in productivity ryzen 5600x spanks i5 so hard it's not even fun watching anymore.
For anyone using PC for ore than gaming, including anyone wanting to montage gaming videos it would be mad to go with intel right now.
The cheapest I can find from two or three well known shops is around £230 for the 10600KF. Also ATM,you can't actually run a 5000 series AMD CPU in a 400 series motherboard until next year.
The issue is if you look at the AMD charts,they state the Ryzen 5 5600X and Core i5 10600K are the same price,and the former has 13% better gaming performance value at stock(which means 13% better gaming performance).
If you look at benchmarks of the various Cometlake S CPUs,the Core i5 lacks thermal velocity boost,which means its much more held back at stock compared to the higher end parts. This is why when you overclock it actually comes quite close to the Intel Core i7/Core i9 CPUs and gains more from overclocking. If you don't believe me - look at Gamersnexus after they tweaked their Core i5 10600K(especially WRT to cache and memory).
The issue is the B550 motherboards are more expensive compared to the B450 motherboards,so even the motherboard cost isn't a big factor anymore(sadly),and for a Core i5 one of the cheaper Z490 motherboards is fine. So you can literally get a Core i5 10600KF,with a decent cooler and a Z490 motherboard for not more than a Ryzen 5 5600X,using the rubbish Wraith Stealth with a B550 motherboard.If you want to actually tweak that Ryzen 5 5600X,you will need to add a cooler at greater cost. Now if AMD had included the Wraith Spire or Wraith Prism,then that wouldn't be a question.
Also for productivity,why even bother with a Ryzen 5 5600X?? I have a Ryzen 5 myself,and mates with Ryzen 7 and Ryzen 9 CPUs get less performance drop-off if they want to try streaming,etc. Its the same reason why a Core i5 will have the same problem against the Ryzen 7 and Ryzen 9 CPUs in those scenarios.
I can literally get a 12C/24T Ryzen 9 3900 non-X in bundle deals with a motherboard for around £310~£325,and there have been deals for the Ryzen 7 3700X recently for around £250. Both will actually run in older motherboards right now.
The Ryzen 5 5600X is stuck between a rock and a hard place. It appears to be a faster Core i5 10600K at a higher price and I think the Core i5 is overpriced too.
We will need to see how the Ryzen 5 5600 non-X pans out. Because in the end neither the Ryzen 5 5600X or Core i5 10600K look very good value compared to the Ryzen 5 3600. The fact is the only SKUs which seem to make any sense in actual pricing are the Ryzen 9 5900X and Ryzen 9 5950X. The Ryzen 9 5900X is actually cheaper per core than the Ryzen 5 5600X!
I think the game should run fine think its issue with that game when I turn off Vsync I get tearing
https://www.reddit.com/r/Amd/comments/izqmc7/rx_5700_xt_on_mafia_definitive_edition/
Also many of these games probably need patching to improve general stability too.
