Any Way To Install Shock Dust Covers Without Taking Shocks Off?
30 Aug 2014
Hi, I have a missing shock cover on my MK6 Golf and have an MOT coming up. Just wondering would it be possible to install these without removing the shock:
I know it's not an MOT failure but just wanna avoid advisories and might be a good idea anyway to help stop corrosion.
I was thinking of running a blade down then wrapping around the shocks and using some type of glue to stitch them back together... or maybe cable ties. Not sure what glue would work on this material?
Eventually I will replace them properly but I'm lazy ATM and not paying someone else to do it lol
Thanks.
No you can't without stripping the strut down.
Even your method of cutting it and glueing it would be an absolute pain to do and probably wouldn't work.
It shouldn't be an mot advisory.
There are only 3 bolts to undo on mk6 golf rear shocks. 10 min job with the correct tools. 21mm socket on the bolt to the control arm and 18mm socket on the 2 bolts at the top if my memory servers me correctly
Why do you want to avoid advisories?
As already stated, this will be incredibly tricky to do nicely without removing the strut and taking off the top mount. How would you get it in between the spring coils for starters?
Just leave it, or take it apart and replace them.
This, the same as the MK5 and Mk4. Very easy job. It makes no sense to start cutting your new shock covers up and trying to glue them back together for the sake of not removing 3 easily accessible bolts.
Think he's talking about the rear shocks rather than the front struts.
What's confusing about that. He said he wants to avoid having an advisory - why would you actively want to do that?
Re-sale is one reason, the cleaner the MOT history the better.
Also its just nicer to have an MOT with no advisories. :p
In any case I don't see why it is an unusual thing to want to do.
Advisories have no impact on resale value as long as they have been resolved.
Maybe. Maybe not. I like a "clean" MOT history. When I put my Clio in for it's last MOT, I asked my mechanic to make sure it had a "clean" MOT. So pre-MOT, fix any potential advisories, BEFORE the actual MOT, so the actual MOT is clean.
When you check the MOT history of a car, one that has zero advisories, or very few, over it's lifetime screams of a car well cared for. One that has advisories at every MOT, especially if the advisories are repeated over several MOT's, suggest a car that has been neglected, at least to some degree.
It may not increase the value, per se. But it may well make it a much easier sale to the right buyer, thus increasing the chance of a quick / more profitable sale.
It's just a Golf ffs...
Oh thats all right then, anyone looking to buy a Golf is an idiot and won't give a damn if it has a clean MOT history or one littered with advisories and failiures. Why bother looking after it in the first place! :p
While helping my brother in law with a car purchase recently which had a leaky CV boot, i found out you could buy split boots with glue as thats what he did to fix it. It seemed a bit unusual to me, but he said the glue seemed strong enough to last.
So yeah, thats a thing :/
Never heard of "friendly mot" stations..... MOT history dont mean ****
