Bug in HDMI 2.1 Chipset May Cause Black Screen on Your Xbox Series X Console or NVIDIA GPU
As I understand it the consoles are not directly affected but rather the latest Receivers are unable to pass-through 4K/120fps or 8K due to some incompatibility in how their chipset operates.
I watched a video on this yesterday, luckily i don't use an AV receiver. Assuming my TV is HDMI 2.1 (uncompressed) like the XBSX i should be fine.
So it was nothing but headlines once again?
Well no, the headlines are correct to a point, but the problem is with current 2.1 AV Amps. The consoles and TV’s are fine. But put a 2.1 amp in between them and you’ve got a problem.
This is annoying especially as the consoles no longer have any separate audio out. There’s always earc though...if it works.
There might be some legs to this impacting PS5? according to Vincent Teoh at HDTVTest PS5 is currently limited to 32Gb/s HDMI 2.1 which means it can only do 4K/120fps at 4:2:2 chroma (not full RGB) and according to a teardown PS5 uses the Panasonic MN864739 (actually Nuvoton technology) HDMI 2.1 chip. I don't know the exact chip the bugged receivers use but I know they were Nuvoton Panasonic chips.
HDTVTest:
Teardown: https://www.4gamer.net/games/990/G999027/20201116053
A description of the bug:
The cause of the problems, it’s alleged, is a known bug in the Panasonic Solutions HDMI chips the AVRs use (Panasonic Solutions is now under the ownership of Nuvoton Technology). The bug apparently affects the way HDMI 2.1’s Fixed Rate Link (FRL) feature works - and unfortunately, early investigations suggest that the problem cannot be fixed by a mere firmware update.
The bug was said to be a signalling issue but perhaps it's a 40Gb/s issue? if the PS5 is limited to 32Gb/s then maybe that is why it wasn't affected by the issue with receivers. Why would Sony limit HDMI bandwidth at the expense of image quality if the hardware is capable?
this might be related to the instant on bug I have, someone else with the same bug fixed it with a hdmi 2.0 cable, this fix I havent tested yet. I do have a capture device passing through the signal.
if they struggle to fix this issue, it serves them right for removing optical out, some times telemetry can lead to awful things happening like features with not many users as a % been removed.
