CPUZ doesn't show correct LIVE Vcore and Core Frequency for Ryzen
29 May 2005
does anyone notice that CPUZ doesnt report correct live information on Ryzen
- Vcore is pegged at the value you dial in in bios rather than the live value (such as Ryzen Master or HWInfo)
- CPU frequency is pegged at the MAX based on ratio or the default rather than the live frequency.
i am sure intel CPU can report live vcore and live CPU frequence. why is it not possible with Ryzen. Had Zen+ Zen2 now both CPU is reported in the same way. it is a bit annoying.
Of course CPUZ reports live frequency and vcore, it always has. If you have set your vcore in the bios to 1.3v and your multi to 42, then that is what cpuz will report.
thats whats in the bios, if you enable global Cstate and other stuff, the CPU frequency will go up and down as shown in Ryzen Master, Aida, HWINfo. same thing wiht the vcore but CPUZ doesnt show any of these live info.
https://www.reddit.com/r/overclocking/comments/eubwjh/ryzen_master_and_cpuz_different_readings_idle/
this is the exact same problem with CPUZ
I have CPUZ showing my 3700x vcore and frequencies which change During idle, gaming and all core tasks.
I don’t have Ryzen master installed at all as don’t see the need for it tbh.
what setting is in your bios for the CPU?
just curious as my current CPU when i slotted it in, it was on auto or default, CPUZ still didnt report changing Vcore. now i am on OC mode wiht undervolt. it is still not reporting changing values despite what Ryzen Master and even HWinfo64 can report.
I have only changed xmp for memory. Pbo is enabled.
Everything else is auto.
I have an msi x570.
max vcore I have seen is 1.2 something, min vcore is 0.9 something.
max clocks on all core is 4ghz. Max clocks when gaming is 4.4ghz.
Curious as to why you want cpuz to show correct data?
I have an msi x570.
It is just an annoyance for me as CPUZ loads up much faster than ryzen master and less bloaty.
1.2V max vcore doesn’t sound like it is the right amount as the CPU is rated much higher than that. When boosting under PBO I would imagine it is hitting high 1.3V.
1.2xx was gaming on cod warzone. Never looked at cinebench tbh, will do now though.
Cinebench shows 1.208 but only 3.9ghz.
Gaming shows 1.080 to 1.296 @ 4.4ghz.
Anyway it does show volts and frequencies moving around along with hwinfo.
btw i am still on the stock cooler for now so see temps hit 77 degrees.
