Caporegime
- 13 May 2003
- Warwickshire
Seems like supply is the new front line for GPUs, so the answer is it depends what I can actually buy for RRP.
Just disable Gsync in Nvidia Control Panel and you'll see what it's like.
For me I don't care about RT this gen of cards the hit's too large still, my valve Index needs horsepower and a 165hz screen so rasta perf is key.
The only thing Nvidia holds for me atm is DLSS 2.0, and Im sure AMD will push theirs 2021 hard but it's unknown for sure I have DLSS on my 20 series and its seen zero use.
People keep talking about how the 6900xt was overclocked with Rage mode, to be clear Rage mode bumps the power available and Rage mode does not overclock the card.
Ampere has almost no overclock!
The fact we are seeing water cooled closed loop cards from AIB already? Suggest 6000 series overclocks well!
A quick Google "Average overclock 5700xt" results in 18%. That's RDNA1 and we are looking at RDNA2, so there is a good theoretical case right now that a well cooled 6000 is going to shizzle all over both the 3080 and 3090 is my thinking.
Yer I saw something along this line too the last couple of days... the Unreal engine is getting native DLSS support and when I think about how many VR games are unreal engine.....I'm thinking the same thing now, my only pause is that we'll see DLSS in VR games soon!
With Nvidia you become a slave and have no choices left as nvidia locks you in to their proprietary stuff.
AMD gives you the best hardware for gaming and gives you choices and options so you become a free man
Seems AMD allows you freedom
What in the world does NVIDIA lock you into?
I have a 2080 and I don't think I've been locked into anything.
Think he was referring to G-sync, which worked and has locked allot of people in, and Nvidia trying to lock you in with DLSS and RT, mostly claiming opensource stuff as their own and forcing customers into that eco system, much like Apple.
And i understand his feelings, as Nvidia and Apple lock people in then stop innovation and only iterate as little as possible to drain as many upgrades for as little work as possible out of everyone.
The world went from being crazed for innovation in the tech world to corporate driven iteration, gg Steve Jobbs great legacy.
Both my TV and monitor are freesync and Gsync
I don't understand blind loyalty to any brand that ultimately just wants your money.
People who are that die hard for a particular brand would buy a turd if it had a certain logo on it.![]()
