Time Spy Standard DX 12 Bench.
CAN SOMEONE EXPLAIN ME WHY I HAVE LOW TIME SPY GRAPHIC SCORE ON RTX 3090.
I have 9700K on stock.
On balance power plan i have only 18.000K and on max perf 19.000K.
Please if somebody can make with balanced power plan test
No need to shout.
If you get a better score on max perf then run it on that, a performance plan for a performance card. :D
My 3090 Strix arrived from OC today at last , quick manual oc and this was the result .. should be able to push it further on the weekend when I've got more time to play :D
https://www.3dmark.com/3dm/52293127?
Score : 20547
Gpu score :21938
Cpu Score: 15117
Intel i9-10900K @5.2Ghz
Asus Rog Strix 3090 Oc , +146 core , +640 memory in afterburner
Driver 457.09
Well done:(:mad::D
Cheers mate :D
Although i doubt it will remain top as more and more people start to get their cards come through , will turn the cpu back up to 5.3Ghz and see what that brings to the table and will try squeeze some more juice out the gpu as well , seeing a 21,000 would be nice but may be a bit difficult on air :D
There is a 500watt bios from evga you can use!
I struggled BIG TIME with my 2x8pin card with only 350watt.
375tuf helped a lot
And 390 from gigabyte was alittle better but mad my fans spin now I have now sold the card to buy a 3pin card
So I can enjoy the 450+ watt power limit
375tuf helped a lot
I will have a look but I doubt the extra 5w would turn into the 500 points needed ;)
Yeah my fans are 100% flat out when set to 495w although it doesn't do to bad the cooler with the card sitting around 75 degrees... not to bad considering its dealing with nigh on 500w but its crying to be put in a water block :D
