I received my Palit RTX 3070 Gaming Pro non overclocked this morning and have to say I am well chuffed with it.
After installing the card I then installed the tools from the Palit website which prompted a firmware update. I also installed the Palit overclocking utility called Thunder Master which has an automate overclocking feature to have a fiddle around with.
First test I carried out was to run MSI Kombustor at stock settings to stress test the card, after 10 minutes the max temperature was just 64C and the fans were almost silent running at around 25-30%.
I then ran Timespy on stock settings and had a total benchmark score of 11631.
Now I'm not experienced in overclocking so just ran the automated overclocking utility in Thunder Master which suggested an overclock of +136Mhz on the GPU offset and +200Mhz on the Memory offset (I didn't touch the voltage). I then stress tested again in Kombuster followed by another Timespy benchmark test which came in at 11944.
My PC is an AMD Ryzen 5 3600 (stock) with 16GB of ram.
Early days but I am very pleased so far. I know quite a few forum members have ordered this card so thought a bit of feedback might be appreciated.
