Bios update, not seen any info on new boards.Will Gigabyte be releasing any new boards for Ryzen 5000 or will they just update the BIOS on the current boards
Yes a good board the msi tomahawk wifi is a good budget option, just check what features you need.I'm looking at the Aorus Master is this a solid board
That's £150 more expensive than needed.I'm looking at the Aorus Master is this a solid board
I've used Gigabyte for years never had a problem, I've used Asus boards budget and high end and always have have problems guess it just my luck
Doubt it - think the aorus master has thunderbolt header on the board (going off my memory here) so official support for thunderbolt won't make too much of a functional difference I'd suspect.New boards can't be much different can they
