Is Godfall actually a AAA game? Kinda reminds me of some of those indie rpgs made with Unity.
Edit: apparently it is.
It cost £70 so it had better be AAA
I agree though looks like a unity job someone coded in their bedroom rather than a Sony first party title!
except it's made in UE4
Sony doesn't own Gearbox![]()
you then added an edit 'apparently it is' without being clear as to what that applied toI said it "reminds me" I didn't say it was made in Unity. This was more attributing to it's overly generic and amateurish look.
you then added an edit 'apparently it is' without being clear as to what that applied to![]()
Full controller teardown.
That plastic worm gear adaptive trigger thing won't five minutes with my big mitts
Yet another tear down that literally tears the controller apart.
This one, the guy actually knows what he's doing, and doesn't break the controller.
Worm drives are perfect for this actually, they have a large reduction ratio, the worm gear (the black round gear) has 26 teeth by the looks of it so it's probably a 26:1 reduction ratio. Which means they can take much higher torque. The electric motor driving it will be high speed/low torque so this is needed to reduce the speed and increase the torque. Guess what else uses worm drives for high torque applications? Winches.
It'll be fine![]()
Haha no - I just like to know how stuff works. All the information is out there really, same with the voice coil actuators they're using.Sooooo how are you so knowledgeable on this then @TallPaul_S ? You're going to tell me you're an engineer of sorts no doubt.
