Thanks for the help, I might just phone them every hour of office hours and see.Soz man![]()
That is huge! Where did you get that from?COD is 136GB for both the S and X versions, so that's just under 40% of the space gone...
I wonder whether the storage is so fast that developers aren't bothering to optimise to the same extent as they would have needed to previously?
File Size (at launch)*
In order to pre-load Black Ops Cold War, you must have the following free drive space on your platform:
PlayStation 4: 95GB
PlayStation 5: 133GB
Xbox One: 93GB
Xbox Series X|S: 136GB
On my order the street isn't shown which is weird, had the house number and post code. Same for anyone else?
Also sea of thieves has been confirmed to be 4k60 on series X.. I'm made up
Box art for ps5 doesn't match that
Has anyone got an order with Argos?
Yeah same on mine too. To be fair all you need is postcode and house number to get a full address if the drivers use sat nav!
I did think it was surprising at the time. With 1/3rd of the GPU power of Series X, 1080p sounds plausible (~25% of the pixels), while 1440p sounds like a stretch (45% of the pixels).Whilst I agree that it may have been a mistake, in all honesty 1080p60 makes far more sense - if you have a 4k TV then you'd go XsX, and 1440p60 is an odd resolution unless you're planning on using a monitor. 1080p60 is great for all those billions of TVs that are sat in bedrooms or for kids use.1080p60 on Series S?
Microsoft are going to regret ever mentioning 1440p with that console, aren't they?I did think it was surprising at the time. With 1/3rd of the GPU power of Series X, 1080p sounds plausible (~25% of the pixels), while 1440p sounds like a stretch (45% of the pixels).
To be fair 60fps on sea of thieves is huge, also its HDR implementation is second to none
I think it's clear now that 1440p will only be used for a 30 fps high quality mode on the SI'm not complaining. 1080p would do me nicely. Just noticing the Series S is getting a bit of flack now that information about performance is starting the filter through. I'm finding myself wondering if mentioning 1440p was a bad idea...
