 - 7 Jul 2008
 - Newcastle upon Tyne
I would like your advise and any pointers re my setup please.
I feel both the CPU and GPU are not running as cool as I had hoped for, maybe I am expecting too much?
Neither the GPU or CPU have been overclocked. GPU is a Zotac RTX 3090 Trinity and has an Alphacool Water Block attached, the rad is an EK PE 360 and the pump/reservoir is an EK Quantum Kinetic TBE 200 D5. The CPU is an Intel i9-10850K and cooled by a Fractal Design 360mm AIO. Water temp is 41deg
I have run Firmark for a hour to give you an idea of temps and put other temps in one of the photos. The GPU block backplate gets rather hot but I understand this is quite usual but to me its maybe adding to head build up inside the Lian Li 011 Dynamic case.
Another problem was I used an Asus Z490 Gaming mATX mobo and you can see how tight the backplate is to the IO and memory.
Fan curves for all fans set to 50% up to 50deg then 100%
So any advice or suggestion for improvement greatly received
Edit: I forgot to turn off Furmark and just looked and the GPU temp was 65deg. So Furmark had been running for about 1.5 hours.
Ambient temp is 20Deg
