I'm in the process of building the Deagostini Millennium Falcon and decided to put a coat of primer (Tamiya Fine Surface Primer) followed by a coat of AS-20 on some die cast metal pieces of the model. It's been drying for a couple of days but the paint is very delicate, where even a light touch/press is causing the paint to flake.
Any ideas? Do I need to strip back to bare metal and try again? Is there a way to "seal" the paint that's on it? I've got some weathering to do to the pieces and am worried the paint will peel/flake even more when I start.
Any pointers gratefully received!
