@smogsy Thanks for the advice. Yes it looks like I'm under powered a little and from what I've read in other posts, Corsair seem to be more prone to exhibiting coil whine. I used the Be Quiet PSU calculator and that also recommended 1000w. I'll take a look for a Seasonic, possibly a 1200w to be on the safe side and maximise quiet operation. Going to lock down my FPS to help in the meantime.
@Stu999 will do.
I’m convinced if you get a titanium power supply your coil wine will be significantly reduced.
once my 3090 Strix is under water I’ll run a 3D Mark Vantage run which is king of causing coil wine. So far I haven’t heard any but the fan is loud enough to drown it out.
They were only hx650s but after 3-years of 24/7 usage of 300w they all started dieing
15 of 70 on 3rd year
55 of 70 on 4th year
Only 3 remain 5 years in
Indeed they was run literally 24/7 zero days off but even so it would save boot up which is painful on the psu.Wow that's some ****** numbers. I suppose its like a hard disk, where certain makes got reputation for dying like clockwork.
I got an XFX bundled with my then 7990 GPU. Both ended up being RMA'd. I payed the difference and demanded a Seasonic replacement, its still going.
I’m thinking about it - sort of reluctant to spend any more money on this rig but may have no choice.
Hi Stu,
I'm in the same situation as you so I went out and bought the brand new "bequiet! Dark Power Pro 12 1200W" PSU for 400$. Just plugged it in and it didnt take away the coil whine from my GPU at least. I would say it became a little bit quiet than before but still very annoying.
Very disappointing,
Ouch. So is it whine from the GPU then and not the PSU?
** remember there is the cardboard bog roll trick to listen that a user shared with us!
Hi mate, yeah seems to be the GPU only, the PSU is dead quiet. Thinking about keeping the PSU and then RMA the Asus 3090 card.
Whats the cardboard bog roll trick you are mentioning? Not familiar with that...![]()
Hi Stu,
Very disappointing,
Did you guys find in use it reduced at all after a while?
tempted to send mine back within 14 days. Idea was it eventually will go under water in a HTPC, yet I can still hear the whine clearly about 3 meters away on the couch and this is with music and ambient noise from games with a atmos setup. Tried with couple of PSUs including my AX1600i which is extremely solid and still it whines so concerned this may not go away even after use. Will be thrashing it this weekend with watchdogs but doubt it will change anything. This is with LG OLED so can go up to 120hz at 4K, but whine happens at any FPS to be honest, all benchmarks I have tried thus far and some games.
Sorry to hear that, do you have coil whine even when you are not gaming?
