New Build Incoming
20 Jun 2005
London..
Coming back to building the first new rig for myself in 10+ years (last one was for my Dad)
I have ordered the following:
MSI MPG B550-I Gaming Mini-ITX
AMD 5600x CPU
Adata 3200Mhz Spectrix D60G 32gb
EVGA SuperNOVA 650W GM 80+ Gold Rated Fully Modular PSU - SFF PSU
Rajintek Metis ITX Case - White
Sabrent Rocket Q 1TB NVMe PCIe M.2
Noctua NF-S12A PWM 120mm Focused Flow PWM
Jonsbo RGB fan 120mm
Cyrorig M9A
Zotac Gigabyte GeForce GTX 1660 SUPER Twin FAN
This will drive 2 x 1080p 75Hz displays
The 1660S is a bit of a stop gap - I will probably dip into the 2nd hand market at some point for a 5700XT or the new 6000 series.
Thoughts? Anything I should change/chop out before it gets picked and dispatched?
Have you checked gpu length for the case ?
Yep, it should fit.
Just thinking now. Is it worth swapping the 1660S out for a Gigabyte NVIDIA GeForce RTX 2060 6GB WINDFORCE OC?
This change would cost £80 more. Just weighing it up.
Thanks. I see the same from the UserBench website. I can get a MSI NVIDIA GEFORCE RTX 2060 VENTUS XS 6G OC for £70 more.
So £70 more for ~15% extra performance doesn't really seem worth it?
I forgot to add I did go with 32GB ram.
