 - 23 Oct 2020
I've been looking on Amazon for an affordable (£70-90) WiFi 6 router. The D-Link AX1800 looks alright (model DIR‑X1860). Anyone got any recommendations?
Yep the honor 3 , but there is my Question on this section about the output of the Chinese version which might be double that of the EU one. Problem is the menu is Chinese, but is web based translatable. I've not seen much in the way of WiFi 6E which is the 6GHz band as yet, or it's still very expensive. There are not many devices which can use WiFi 6 yet but buying the latest tech does give some degree of futureproofing.
Why would you buy the Chinese one? It'll be great craic when it just causes massive interference all round your home. The extra transmit power is pointless and it's just causes RF pollution. There are reasons why devices are limited like this, and generally it's just common sense to accept that. And the thing is that gullible folks see 200mW vs. 100mW and they think BETTER!!!!
It's not. If you need more coverage, add more access points. You'll be a lot happier in the long run.
Honor is Huawei. So it'll probably be pretty good. I hadn't actually spotted this device before but I'm getting one in to test. For £41.67+VAT how bad can it be?
Every access point in the world can output more than 100mW but they limit themselves to comply with legislation.
You’re waving the inverse square law about but in reality access point signal strength is usually not the issue in domestic properties. The problem is cross-over interference. You’ve already been informed that you can only have a 2-way conversation if both sides can hear and speak to each other at the same volume. A 100mW AP can already comfortable out-shout any hand-held mobile device and even laptops and PCs will only be replying at 85-100mW so your 200mW super-amplifier is utterly pointless.
And as for how these work in overcrowded Chinese cities? They don’t. Just because it’s available doesn’t mean it’s what people actually use.
Both are true, but why would Huawei be an issue?
I guess he's saying that if it's made by Huawei it might as well be made by the Chinese government.
I was looking at the Honor 3 as well, an upgrade from the standard Virgin SH3, would it give me better range?
Cheers mate, might be worth a try, its free returns so could always make use of that.Possibly, its hard to know. I bought one for a specific use case, with the Quest 2, its the only thing that is using the Honor router. The benefit being Quest and Honor are WiFi 6.
It seems to get similar coverage to my Linksys WRT 3200 ACM, which is plugged into the Virgin SH3, cant tell if its going to be better than a SH3 in your situation/house/layout. I would expect its quite similar.
Might be daft but if I get a WiFi 6 router will it be backwards compatible with non WiFi 6 devices?
