As it looks like I'll be working from home semi-permanently, I've been given a budget by my work to upgrade my WFH setup. I'm wanting to spend a maximum of £600 of it on the monitor(s).
I don't use my computer for gaming, media consumption - basically anything but work. For work, I'm pretty much in spreadsheets or coding so colour accuracy and response times aren't particularly important to me. There's a lot of multi-tasking and collaborative work though, so I've always got a bunch of windows open. All of which has led me to think that I should probably get a pair of 1440p monitors in the largest size that fits in my budget. I'll be connecting them to a Macbook Pro so if they have USB-C that's a bonus, but it's certainly not a deciding factor.
At the moment I have the 15 inch Macbook Pro screen itself, a 22inch 1680x1050 display and a 24 inch 1080p display - both of which I'd be looking to retire.
Options I'm considering are:
- 2x Dell P3221D (32inch, 1440p USB-C monitors, 60hz, 350 lumens, 1000:1 contrast ratio), which at £344 take me a bit over budget
 - 2x AOC Q3279VWFD8 (32inch, 1440p, 75hz, 250 lumens, 1200:1 contrast ratio). which at £215 come in well under budget
 - 2x ViewSonic VX3276-2K-MHD (32inch, 1440p, older model, 75hz, 250 lumens, 1200:1 contrast ratio, but seems pretty well-reviewed) at £199 feels like a bargain
 - 2x Samsung LU32J590UQUXEN (31.5 inch, 4k, 60hz, 270 lumens, 3001:1 contrast ratio) - at £330, like the Dell, it pushes me slightly over budget, but gets me 4k for clearer text and/or a huge number of pixels to play with.
 not work related...
