I actually thought it got deleted I never new it would be this hard.
CPU = Needed?yes
MOBO = B550
GPU = Needed?yee
PSU = Needed?yes
RAM = 2x16GB
CASE = 7 Fans
This sound right OP? That all right
Do you need a copy of Windows 10?yes
Do you need a KB&M?got one
Do you need a monitor?got one
What is your budget for the things you need?maybe £500-800 without graphics card a will get that spread
This should be a good start for the system spec'ers to be able to sort you out a parts list
I hope this answers everything so no ones confused am trying to post stuff from overclockers but don't know how!!? I couldn't find the thread I don't know how??
I was gonna get the ryzen 7 300x unless someday can suggest a better one and I just need help with the rest and donno if £500-£800 is over kill with out the graphics cards??
CPU = Needed?yes
MOBO = B550
GPU = Needed?yee
PSU = Needed?yes
RAM = 2x16GB
CASE = 7 Fans
