RAGE MODE!!!
What power supply would 8 of these cards need if the maximum PSU available is 1650 or 1800W?
RAGE MODE!!!
There must be an error in Sapphire specs.
RTX 3080 320-watt + Core i9-10900K requires a 750-watt PSU.
Why does Sapphire want 850W PSUs for cards which are supposed to be more power efficient than RTX 3080?![]()
https://www.sapphiretech.com/en/consumer/nitro-radeon-rx-6800-xt-16g-gddr6
More info on that Sapphire card if people want to take a look.
850W PSU minimum... interesting.
What if you have a Threadripper, a 3 m.2 drives, a 4 ssd and one mechanical hdd plus like 7 case fans? If 140mm onesTo power a 300 Watt GPU and something like a Ryzen 3000 or 5000 CPU this is the lower limit. This is acceptable. https://www.overclockers.co.uk/be-quiet-pure-power-11-600w-80-plus-gold-power-supply-ca-12y-bq.html
Don't get something like this.... https://www.overclockers.co.uk/kolink-core-series-700w-80-plus-certified-power-supply-ca-02q-kk.html
PSU ratings will be taking into account that most PSU's are really REALLY bad.
A good 650W - 700W should be fine for most non OCed systems (R5 3600 / 5600X or i5 10600k)
i have a EVGA SuperNOVA 650 G2, 80+ GOLD 650W
i think im going to try and get a 6800xt, are you saying my PSU is enough for it?
If you're unable to be available perfectly on the hour because of work, it doesn't make any difference if it's 5 seconds, 5 minutes or similar. You've missed it.
But the effective bandwidth of 6800 depends on the assumption that the Infinity Cache will still maintain a 58% hit rate in mining like it does in 4k gaming currently.
For perspective, if cache hit falls to 0% the effective bandwidth of navi drops to 512 GBps.
Yes, that's more than enough. Very high quality PSU.
I have an EVGA Supernova 650 GS.
Ryzen 3600
2070 Super (overclocked)
1 mechanical drive
1 M.2
2X SSD
AIO
1 120mm Fan
3X 140mm Fans
The PSU rarely gets warm enough to spin up its fan.
I ran a 3900X + FuryX(300W card) + 4*8GB RAM + 7 SSD's on my 650W G2, now have a 5700XT and it works fine.i have a EVGA SuperNOVA 650 G2, 80+ GOLD 650W
ok thanks for this
