MSI MEG UNIFY - CPU Failure Light 5900x
It mite be worth trying the previous bios 7C35vA6 which I believe supports ryzen 5000.
https://www.msi.com/Motherboard/support/MEG-X570-UNIFY
I've dropped down to version 7C35vA6.
Fingers crossed that this fixes the issues!
I had a couple of Windows Start Menu lock-ups last night but decided to leave the PC on overnight and was greeted by a black screen this morning.
The ram model number is: CMW32GX4M4D3600C18
Load optimized defaults, reboot, back to BIOS and go through and check that you definitely have no OC enabled, XMP is off so RAM is running at the default 2666MHz, see if its now stable.
Was Sleep mode and hibernation turned off In windows ?
Yep, I set going to sleep to 'Never' and also turned off the HDD going to sleep.
I forgot to mention this morning, I needed to clear the CMOS to get it to boot past the 07 code and back to Windows.
This has obviously dropped the XMP (default profile 1) setting and the RAM is back to 2133 MHz.
Quick update:
So, the first test passed with no issues.
I then decided I would try the default 1 XMP profile first (3600Mhz). I selected it in the BIOS, saved and when it rebooted it failed to POST.
The DRAM light was lit up on the motherboard with the debug code 0d.
I then reset the CMOS (back to 2133Mhz), and it posted fine.
Tried to set it to the default 1 XMP profile again and it failed to POST again.
Quick update:
Mine did the same. Try :
XMP OFF
Manually set RAM @ 3600mhz (3700 also worked)
Change RAM voltage to 1.40v
Everything else Auto
SAME ISSUE X570 UNIFY. when XMP enabled it doesn't boot.
have 32gb crucial c16 3600mhz
tried on V6 and v7 bios.
tried with 1 stick in running XMP enabled - no post
tried with the other stick alone
Just set to 3200mhz. gona try up the voltage now, like you say
edit: got it working on 3800 , 1900 FLK c16. gona try 4000 / 2000 tomorrow
Ok so if i set the voltage to 1.4 and 3600 or xmp present 1 or 2 after a bios reset I get ERROR NO POST
workaround. downrank your memory frequency. i used 3200 and set voltage to 1.4
rebooted. seems it wants the extra power before upping the frequency.
set frequency back up to 3800 and reboots fine 1900FLK 1:1 stable.
seems like a bios issue hopefully MSI will fix it soon. Does that work for you guys who are also having this issue?
