Looking for an advice regarding my upgrade.
10 Nov 2020
Hi guys, so I've put some parts together and I was wondering if you could check them out and tell me if its all good and compatible. also maybe there is something better out there for gaming since I have couple more quid to spent. Ill link below the parts I picked up. Thanks :)
https://www.overclockers.co.uk/inte...ocket-lga1200-processor-retail-cp-68s-in.html
https://www.overclockers.co.uk/asus...-lga-1200-ddr4-atx-motherboard-mb-6ee-as.html
https://www.overclockers.co.uk/cors...3600mhz-dual-channel-kit-black-my-4a5-cs.html
https://www.overclockers.co.uk/asus-rog-strix-850w-80-plus-gold-modular-power-supply-ca-05k-as.html
What's your budget?
Do you have a graphics card already, and if so what?
What monitor and resolution do you use?
Do you have an SSD?
budget about 900
Yes, Currently have rtx2080. monitor is asus 1080p 144hz 1ms. I do have ssd.
Also I have mid tower and aio so would prefere if everything would fit in there.
Whats the make of PSU you have? Might be a good idea to change it but that would depend on how old it is & its quality.
Yes they are all compatible and you will be able to overclock. That's also a fine psu that you have chosen. It has huge heatsinks so it should be very quiet plus it has a 10 year warranty.
However, that is a hell of a lot of money for a Z490 motherboard and I would be looking at the boards in the £170-180 price bracket, there are some good deals on at the moment. Personally I would be looking at AMD who seems to have taken the lead in performance (gaming included) with the 5000 series release. If that means waiting for stock to come in then so be it. It's not as if your current setup is no longer any good (unless something is broken). Better to make the right choice in the first place than regret it later down the line.
