Hello,
I live in an area where we can't get fibre-optic and the quickest connection possible is a 1MB download speed and about 2 upload (yes it's that bad)... I spoke to a chap near me who is using mobile home broadband where he has a 4G sim router and the internet connects through the 4G. He gets upto 40 mbps. I went for the same option, but my signal is no where near as good to where he lives unfortunately, but someone mentioned an external antenna which will fit into my router, but would need to be put up outside on the house etc like a sky dish. I'm happy to try this, but I'm wondering if it will actually improve the signal and speeds and latency? The router I have is a Huawei b535 which does have antenna ports on the back to connect a antenna too. Any thoughts would be great. I believe I have found out where the nearest mast is also so I was thinking an OMNI DIRECTIONAL antenna in that direction then straight into the router. I just don't want to go ahead and do all this if it's not going to help, but reviews have said it does
) Although i disagree with about the latency there too.... I used to pole fish a lot and being able to whip in those little roach every 20 seconds won me a few local comps
