- 14 Oct 2007
- newcastle
All of a sudden I keep getting black screen unresponsive crashes when I’m gaming could my new 3080 be causing my M2s to overheat and crash the system?
Its a weird one for me I do t think it’s my ram as it’s only at 1.35v, I was playing games all day then all of a sudden last night I would get the game freezing pc crash or a black screen crash, I’m sure it’s down to airflow as my 3080 is right against my intake/RAD of my O11, I may have to buy the XL version and sell this to solve my problemI had to dial back my ram voltage due to the extra heat given off.
I have the Silverstone RL06 which has really good airflow but even then I had to reduce my ram voltage down from 1.49v since installing a 3080 as the heat it kicks off is crazy compared to my old 1070ti.Is this your sig rig? What is case and case fan setup? Might be as simple as improving case airflow. Basically every degree warmer air is entering cooler than room makes that component same degrees hotter. So if room is 22c, air entering cooler should be less than 25c. If it air flowing over component is 35c then improving case airflow and lowering it to 25c will lower component temp 10c.
60C would be certain crash for Samsung B-die.Just to update, I think it was my ram the 2 Center sticks were getting upward of 60c just before a crash, I have put a 120mm fan blowing on them for now and so far so good
