Hey all, I need your expertise!
My own PC seems to be running Fortnite just fine on maxed settings at 240FPS, and it'll hold it very well, however my brother's PC which is almost identical seems to be having an issue where it's only running at 170-180FPS in the exact same area and it'll dip even lower in busier areas. The problem is only specific to Fortnite, we have tested Doom Eternal, COD, and NFS: Heat - Any help is much appreciated!
We're on the same graphics settings, same drivers, tried updating BIOS, tried enabling Hardware-accelerated GPU scheduling in Display Settings -> Graphics settings, and also have identical settings in NVCP (GSync On, Vsync On, Max Performance etc - have also tried complete defaults). I've tried uninstalling GeForce Experience on the other machine because I thought that perhaps the optimiser had messed something up but that didn't change anything either.
Both PCs are running a fresh installation of Windows. I have tried using DDU to re-install the driver.
PERFORMANCE COMPARISON IMAGE: https://i.imgur.com/visiLmN.png
My PC Specs [CPU Temps: 55c, GPU Temps: 70c] [Timespy Benchmark] :
9900KS @ Stock (5Ghz)
64GB 3200 DDR4 [XMP 1 Enabled]
MSI RTX 3080 Gaming X Trio
Asus Maximus XI Hero
1TB NVMe Samsung Evo Plus (Game is installed here)
250GB NVMe Samsung Evo Plus
2TB 7200RPM Samsung HDD
EVGA SuperNOVA G1+ 650W
Acer XF270H A Gsync Compatible Display [Enabled G-Sync in NVCP]
Other PC's Specs [CPU Temps: 50c, GPU Temps: 65c] [Timespy Benchmark] :
Asus Maximus XI Hero (WIFI)
EVGA SuperNOVA G1+ 750W
Any help is much appreciated thank you!
Something important to note:
Something strange happened last week, after a day or so of using the PC after a fresh Windows installation, I launched Fortnite to play and also experienced the same poor performance, the 240fps had reduced down to 170 and if I looked and GPU-Z, it showed a close similarity to the other PC's readings, ie lower gpu usage, lower power draw etc - not sure if this is related or not and am unaware of anything I could have installed or done to have caused this.
I tested a lot of things such as doing a clean driver install, trying it with DDU, updating the driver etc, and nothing worked. I reformatted my PC and the high performance came back back, and I've had no issues through the week either no matter what I've turned on and off to try and mimic this problem that I previously had, and the problem the other PC is currently having, it now runs at 240fps constant - I'm pretty perplexed and feel I have exhausted just about every idea I have and forum post I've read; I have also tried the solution in another thread which was enabling the Ultimate Performance power plan with no success... I don't want to format the other PC because I don't know what actually fixed it, and I have no idea if this problem will come back.
despite being essentially clones of each other.
