Hey all,
I was happy to finally finish my build after getting Ryzen 9 5900x, but unfortunately I was disappointed with the performance of MSI RTX 3080 GAMING X TRIO after comparing the results to what I found on the internet.
I checked multiple games and benchmarks. Here you can say my result for 3DMark Time Spy:
Score: 16526
Graphics score: 17230
Graphics test 1: 113.45 FPS
Graphics test 2: 97.92 FPS
The expected Graphics score should be 17832 for the founder edition and 18683 for my card.
https://www.guru3d.com/articles_pages/msi_geforce_rtx_3080_gaming_x_trio_review,26.html
After monitoring I realised that the problems is related to the core clock not being boosted enough. It is alwyas below 1800 MHz, while it is supposed to be boosted to 1815 MHz, and other cards are reaching more than 1900MHz normally without overclocking.
I tried to overclock the card using the following settings:
Core Voltage: +80
Power Limiter: 102%
Clock: +135 MHz
Mem clock: +500
FAN RPM default.
The core clock was between 1850-1900 MHz and I gained good performance boost. Then I tried to overclock it more by using Clock +200 MHz, and the clock was between 1900-1930 MHz.
There is always one pattern happening at the default settings and also while overclocking. There is always spikes in the clock. This's fine in the default settings, but will make problems while overclocking since I saw the clock spiked to more than 2150MHz. Here you can see the three runs I talked about and the spikes:
https://i.imgur.com/xDTfy9q.jpeg
So why do you think the clock is not boosting by default to a reasonable value? card temperature while gaming is not exceeding 75 even with overclocking. I am using 3X8 pins connectors for the card. For software tried to prefer performance over power save, I reinstalled Nvidia driver and even reinstalled Windows but without luck!
If it's not possible to find out the reason for that, then how can I overclock it to have around 1900MHz but without those spikes? I tried the auto performance tuning in Geforce experience, and it gave me around +130MHz without the spikes I was talking about. The performance gain was acceptable, but not the best, so I would like to overclock it manually.
Here is my build:
Asus ROG Crosshair VIII Hero
AMD Ryzen 9 5900X
MSI GeForce RTX 3080 10 GB GAMING X TRIO
G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16
Samsung 970 EVO Plus 2 TB M.2-2280 NVME
Corsair RMi 850 W 80+ Gold Certified Fully Modular ATX Power Supply
Score: 16526
Core Voltage: +80
Power Limiter: 102%
Clock: +135 MHz
Mem clock: +500
FAN RPM default.
Here is my build:
AMD Ryzen 9 5900X
