Bit more than I'd like to spend really, looking at £50 topsArctic Liquid Freezer 2.
I use the 360 version of this (for a 3600X) and get idle temps of 26-30c and full load between 55 and 60c
Great cooler.
If that's out of budget then go air and get the Freezer 34 esports duo
Will it handle a clocked 3700x? Been reading lots of reviews and most says for 8 cores that most air coolers are a mediocre?If that's out of budget then go air and get the Freezer 34 esports duo
I only have a 3200G in my NAS but the esposrts keeps that running prime under 50. However I imagine you'd need to add a minimum of 15c to a 3700X for that.Will it handle a clocked 3700x? Been reading lots of reviews and most says for 8 cores that most air coolers are a mediocre?
It's will fit and I have seen it, but the gamers nexus (?) Review put me right off it.. comes with pre applied paste as well and I already have some kryonought stuff so would need to get some cleaner...This one is going for a good price right now provided it will fit your case.
My basket at Overclockers UK:
Gamers nexus only slated it because it was more expensive than the D15 at $100 and performed slightly worse but at 34 quid vs an £85+ noctua it's a steal.It's will fit and I have seen it, but the gamers nexus (?) Review put me right off it.. comes with pre applied paste as well and I already have some kryonought stuff so would need to get some cleaner...
Canucks don't do performance testing well. Stick to the GN review, if Steve likes it it's probably good.
What sort of temps are you hitting under load?I've been running the Arctic 34 duo on my 3700x and it boosts to 4.5ghz happily and only makes a slight hum when under load.
Can't complain about it for the money.
