Cleaning tape marks off carpet
21 Jan 2010
Our carpet has sticky tape marks on it, and I've tried warm soapy water, but can't get them off. Also tried using a vax- no luck.
I just can't get the adhesive residue off.
Any recommendations?
It damaged mine, also depending on how the carpet fibers are attached to the backing, it can dissolve the glue.
my carpet is not high pile and is not damaged. I think it depends on the quality and composition of the carpet. especially when using nail polish remover, it does not attack the fibers as hard.
