COD Warzone - optional High Resolution texture Pack - xbox issue
30 Nov 2003
Got an option to install this pack during first install today (xbox one x) though install had already taken a long time what with then running into issues setting up new activision account etc.....so though would download this later.
However now struggling too find the option anywhere obvious...can anyone point me in the right direction (google advises game install menu?)
Have you paid for the X version?
Appreciate reply I downloaded the free version of warzone (83gb)and the option for the high resolution texture pack came up directly after Activision account set-up. Skipped passed it at the time (with intention d/l later) & now trying to find where I can install it. This link suggests accessing via the game install menu:confused: am playing on the one x. Apparantly the pack is suitable for one x , series s/x & ps4 pro/ ps5
edit: also this Activision link refers to game install menu
"If you don't accept the prompt the first time you log in, you can navigate to the Game Installs menu to download and install the texture pack"
It sounds like the issue I had with PC and annoyingly I had to delete it and reinstall it quite a few times before it worked
Go to My apps and games --> games --> select warzone on the right --> manage game (2 squares button) --> select the game install
Then just tick the pack in the list to install --> save changes
Assuming you have the latest dash, the manage game section changed slightly recently.
In the warzone menu press the Xbox menu button the 3 lines to bring up options.
You will have audio, general, controller and account along the top maybe in different order.
Under general I believe near the bottom is game installs option this should so you what's installed and allow you download what's not.
If not search the Xbox Store for the pack.
Go to manage games and apps and look at the options for warzone.
Hope that helps
Thanks for your help fellas.......still struggling :)
Did try a re-install overnight but not getting the texture option at install just goes straight to game
Thanks unfortunate only the 80Gb game installed shown here with no add on options
Hope that helps
Thanks have checked again no options within warzone menu under the general section (or any of the other sections from what I can see) Have checked market place again but can see no obvious options.
Hit the option button on the game under my apps and games, and then manage game and add ons and you'll see all the optional data packs.
Thanks for your help unfortunate only the typical paid for content company coin etc showing...... no texture pack
If you go to manage game from the Xbox home screen you can download it there.
Thanks guys unfortunate no optional add ons available in my apps and games using your advice...have even tried re-set / clear cache
Am thinking need to delete both the game and my activision account and start again...if only I clicked on the first link at initial install:p
I have a feeling with the free version of warzone sometimes its temperamental showing game installs in the options menu.
If I was you delete the game. Reboot the console and download again.
I would have thought using the same Activision account will be fine.
