What settings and resolution are you running at?i cant even stay above 100 on warzone, 3700x, 16gb 3200CL16
1440p doesn’t matter if settings are low or high FPS won’t move above 120What settings and resolution are you running at?
Same issue here, with low GPU usage in windows. Its really frustrating!1440p doesn’t matter if settings are low or high FPS won’t move above 120
Same gpu usage is low in every game I play, can’t even hit 60 FPS on ultra on gta lmfao, think I may need to rma my cardSame issue here, with low GPU usage in windows. Its really frustrating!
Thing is with my card is it’s fine in benchmarks but dog **** in gamesThis really just seems to be an msi issue from all the threads ive been reading including my own case, just over 15000 gpu score on 3d mark when others are getting 17-19k scores.
edit - my card performs under an rtx 3070
Timespy? Like 17.5k gpu, 10k cpu I think 3700xwhats scores you get in 3d mark ?
I have a MSI ventus and see relatively similar results. If you have msi afterburner or some other monitoring tool you will be able to see the card is constantly power limited
Overall is 16k but games run so bad it’s unreal
https://www.3dmark.com/spy/15364033 Nvm I was close to guessing logged in and got the link
I will be flashing the 3090 Gigabyte gaming OC bios on my card(Msi 3090) if MSI don't play ball and give me a 400W bios
Your score is better than mine in benchmark.
did you try another game other than warzone?
Can you please tell us your experience after trying it? I thought about it but I am hesitant to be honest since it's not from MSI.
every game runs awful, i cant even hit 60fps on gta v ultra, ive seen 4k benchmarks hit higher lmfao, honestly either my card is doomed or my whole pc is a jokeYour score is better than mine in benchmark.
Just to check people have “prefer performance” selected in the global setting within the Nvidia display panel?
I’ve got MSI 3080 Trio and 5900x and have scored just over 19k for GPU with an overclock and 18k overall score in time spy, I’ll check what it scores at on default settings.
so totally standard fan curve and no OC gives me Graphics score of 17846 on time spy
That's a big improvment. Can you tell us your OC settings?
