That is the AMD reference design... only AIB custom cards would theoretically change thatAnyone have a clue as to whether any of these cards with have 3 displayports? All the ones If seen just have 2 plus HDMI plus USB-C
Appreciate there are converters but it's not ideal for 2 monitors + VR
What exactly is the issue with not allowing reviews 24hrs before release? I've not read one valid reason yet.You do realise that ordering a card isn't final, that makes absolutely no sense.
If you order a card and read a review that would change your mind on the purchase you can... change your mind on a purchase. either cancelling the order or sending it back for £5. No one is going to spend what £500-1000 on a card(depending on which one) only to go oh it sucks, better keep the order. I mean even if 6 people do that, you think AMD are doing it to get 6 extra sales?
I'm going to try to order one, if the reviews show it's bad it's getting cancelled or being sent back.
I think if you use that it generates a new OC account so it wouldn't be linked to your forum account. There may be an option to merge multiple OC accounts though.
Gigabyte one starting now.
if hiding the product pages helps stop bot's or scripts then I'm for it.Seems totally ridiculous at this stage for an NDA to hold influence over retailers to even put up product pages or for reviews to be released.
AMD can do no wrong?
2.4-2.5ghz! jeezGigabyte one starting now.
it wasn't worth a watch in endGigabyte one starting now.
2.4-2.5ghz! jeez
it wasn't worth a watch in end![]()
