Very nice, love the stock
Thanks, got a ding in the side which you can see in the pic (gun was a display model so got a little off it for that) just above the trigger. See if I can patch that up and it'll look grand
Thanks, got a ding in the side which you can see in the pic (gun was a display model so got a little off it for that) just above the trigger. See if I can patch that up and it'll look grand![]()
What are they ? Ipads ?
Could do a LOT better for £70Normally not my ideal headphones, but for £70 new worked out okay for gym use vs current cable ones.
I suppose you are somewhat limited in your options in that regardSure, for general music there’s better, but not for working out.
Haha. It is a bit like that
I disagree.
Powerbeats are exceptionally comfy, sound great, with a slightly bass heavy sound which is great for the type of music one tends to listen to at the gym.
I’ve tried a lot of earphones for the gym, and my power beats Pro were better than all of them.
Enjoy
Yes it's in the dining room. Yes we are still waiting for the kitchen extension to be finished.
Enjoy
I didn't think I'd get sucked into the hype this generation but here I am looking for PS5 stock!
