- 3 Oct 2020
If you follow discord/telegram stock channels you can easily get a card for near rrp.... there have been loads of 3080 drops recently near rrp prices. Personally bang for buck id take the 3080.
If your time is worth £0/hr maybe. Otherwise it's cheaper to pay the scalpers.If you follow discord/telegram stock channels you can easily get a card for near rrp.... there have been loads of 3080 drops recently near rrp prices. Personally bang for buck id take the 3080.
This:10GB will be enough until it's not but by then it won't matter as you'll be running a slide show.
I think you're missing the point, if you can upscale, downscale or whatever and not see the difference then the point becomes moot. Consoles don't produce the same image quality as top end GPUs or at least not in independent tests or for my eyes. Therefore the banal 'buy a console then' statement doesn't really contribute a whole lot.
Why not Zoidberg?
How come upscaling has become acceptable!?¿
Care to qualify that one?If you follow discord/telegram stock channels you can easily get a card for near rrp.... there have been loads of 3080 drops recently near rrp prices. Personally bang for buck id take the 3080.
"upscaling" isn't really accurate. DLSS is a wonderful concept and it's genuinely surprising how well it works given its infancy.
think of how sight works, you don't actual "see" the pixels of the world, your eyes do and then it is processed in a way that makes sense for your brain. DLSS is essentially doing the same thing, taking a rendered image and rebuilding it as "it should be" using machine learning.
as a technical feat that we're at a point where its already producing an image that is nigh indistinguishable from its native counterpart while largely matching the performance of the subject resolution is incredibly impressive, even if you have no interest in using it. it's a complete different paradigm to clumsy one size fits all upscaling techniques. proper sci-fi stuff.
I don’t think they are. I have seen quite a lot of people trying it off load their scalped 3070 today. Not many are being bitten. Only the desperate and uninformed are paying over the odds prices.The Bots are winning
It's amusing to see people post that and then spend hours here on this forumIf your time is worth £0/hr maybe. Otherwise it's cheaper to pay the scalpers.
But we stopped skynet from becoming self aware?The Bots are winning
LOLUpscaling then!?
Brutal.I want to see some 6800XT VR benchmarks, but I would take a 3080 or a 6800XT and be happy with either.
I like the novelty of the FE cooler, so if I could get whatever, I would probably go with the 3080 FE. Nice clean looking card.
However, AMDs offering is strong enough that I'm not waiting on any 3080 if a 6800XT is available when a 3080 isn't.
