£1500 Budget White Glacier PC
Hi
Yes the pc you are looking at is a very cable gaming and streaming but I would up the memory to 32gb.
Be aware that there is a wait for the 3080 gpu so you may not get this before Xmas. There are problems with availability of new parts.
would there be anyway of getting this pc style down to a £1500 budget without changing the style/case of the pc.
I thought about adding an i7 10th gen, Dropping the graphics card and changing the Solid State memory card. would this work?
You can put all the parts you want together and overclockers will build it yo your spec.
There's no way on that build to cut £1000 off if you drop the graphics card you ain't got gaming machine what would you use ?
The problem is also availability .
